Wine, libs, Crookz The Big Heist (fixme:d3d11:D3D11CreateDevice, driver_type, D3D_DRIVER_TYPE_UNKNOWN)
Вопросы настройки, запуск любых Windows-программ, кроме игр
Ответить
byNickSan
Сообщение byNickSan »
Здравствуйте, прошу помочь понять и решить суть проблемы, я полагаю все из за того что вайн x64, но что с того?
wine '/media/USERNAME/AAA000/.../Crookz The Big Heist/Binaries/Win32/Crookz.exe' fixme:heap:HeapSetInformation (nil) 1 (nil) 0 Connection to "Provider=sqloledb;Data Source=production-db;Initial Catalog=EngineTaskPerf;Trusted_Connection=Yes;Connection Timeout=2" or "10.1.20.20" failed fixme:gameux:GameExplorerImpl_VerifyAccess (0x14c2c0, L"...\\...\\Crookz The Big Heist\\Binaries\\Win32\\Crookz.exe", 0x1e4f1b4) fixme:win:EnumDisplayDevicesW ((null),0,0x1e4f334,0x00000000), stub! fixme:d3d11:D3D11CreateDevice stub: adapter 0x153598, driver_type D3D_DRIVER_TYPE_UNKNOWN, swrast (nil), flags 0, feature_levels 0, levels 0, sdk_version 7, device 0x1e4f68c, feature_level 0x1e4f800, context 0x1e4f690 Warning, Command line -d3d11 set, but D3D11 is not supported on this machine. Will fallback to older API. fixme:dbghelp:elf_search_auxv can't find symbol in module fixme:dbghelp:validate_addr64 Unsupported address fffffffff71c0000 fixme:dbghelp:validate_addr64 Unsupported address fffffffff71a0000 fixme:dbghelp:validate_addr64 Unsupported address fffffffff67f0000 fixme:faultrep:ReportFault 0x1e4f320 0x0 stub fixme:system:SystemParametersInfoW Unimplemented action: 59 (SPI_SETSTICKYKEYS) fixme:system:SystemParametersInfoW Unimplemented action: 53 (SPI_SETTOGGLEKEYS) fixme:system:SystemParametersInfoW Unimplemented action: 51 (SPI_SETFILTERKEYS)
WINEARCH=win32 winecfg
wine: WINEARCH set to win32 but '/home/USERNAME/.wine' is a 64-bit installation.
Ответить
