x2go (кто использует)
Rosinka32
Re: x2go
Сообщение Rosinka32 »
добрый день всем! Помогите с вопросами по x2go - просто устал. Установил x2server. printing, cups-x2go,
Создал юзера. В итоге - подключается, но не печатает и нет звука. Звук ладно... Но принтеры очень важны....
Что имеем Debian Wheezy - server, Client Linux Mint 17. Syslog об x2go гвоорит следующее:
Dec 1 10:21:23 TServer /usr/sbin/x2gocleansessions[6032]: x2gotest-50-1417418483_stDXFCE_dp24: state file for this session does not exist: /tmp/.x2go-x2gotest/C-x2gotest-50-1417418483_stDXFCE_dp24/state (this can be ignored during session startups)
Dec 1 10:21:23 TServer /usr/sbin/x2gocleansessions[6224]: x2gotest-50-1417418483_stDXFCE_dp24: state file for this session does not exist: /tmp/.x2go-x2gotest/C-x2gotest-50-1417418483_stDXFCE_dp24/state (this can be ignored during session startups)
Dec 1 10:21:24 TServer /usr/bin/x2gostartagent: successfully started X2Go agent session with ID x2gotest-50-1417418483_stDXFCE_dp24
Dec 1 10:21:25 TServer /usr/bin/x2gosetkeyboard: Setting X keyboard according to /home/x2gotest/.x2go/C-x2gotest-50-1417418483_stDXFCE_dp24/keyboard
Dec 1 10:21:25 TServer /usr/bin/x2gomountdirs[10602]: WARNING: mounting of /home/it-user/.x2go/S-x2gotest-50-1417418483_stDXFCE_dp24/spool failed
Dec 1 10:21:25 TServer /usr/bin/x2goruncommand: launching session with Xsession-x2go mechanism, using STARTUP="xfce4-session"
Dec 1 10:24:23 TServer /usr/lib/cups/backend/cups-x2go[12667]: Print job received from cups -> 1 x2gotest Безымянный1 1 PageSize=A4 job-uuid=urn:uuid:0e7af823-b0d7-3af0-6328-f2e9cb783221 job-originating-host-name=localhost time-at-creation=1417418663 time-at-processing=1417418663
Dec 1 10:24:24 TServer /usr/bin/x2goprint[12693]: x2goprint is processing /var/spool/x2goprint/x2gotest-50-1417418483_stDXFCE_dp24_1-x2gotest-cupsjob12667.pdf with print job title ,,Безымянный1''
Dec 1 10:25:12 TServer /usr/bin/x2goresume-session: client 10.32.14.29 has successfully resumed session with ID x2gotest-50-1417418483_stDXFCE_dp24
Dec 1 10:25:13 TServer /usr/bin/x2gomountdirs[13610]: WARNING: mounting of /home/it-user/.x2go/S-x2gotest-50-1417418483_stDXFCE_dp24/spool failed
Dec 1 10:25:14 TServer /usr/bin/x2gosetkeyboard: Setting X keyboard according to /home/x2gotest/.x2go/C-x2gotest-50-1417418483_stDXFCE_dp24/keyboard
Dec 1 10:25:19 TServer /usr/lib/cups/backend/cups-x2go[13728]: Print job received from cups -> 2 x2gotest Безымянный1 1 PageSize=A4 job-uuid=urn:uuid:d8e1d943-bada-33e6-56ad-a41f597c600e job-originating-host-name=localhost time-at-creation=1417418719 time-at-processing=1417418719
Dec 1 10:25:20 TServer /usr/bin/x2goprint[13753]: x2goprint is processing /var/spool/x2goprint/x2gotest-50-1417418483_stDXFCE_dp24_2-x2gotest-cupsjob13728.pdf with print job title ,,Безымянный1''
Dec 1 10:25:29 TServer /usr/bin/x2gosuspend-session: session with ID x2gotest-50-1417418483_stDXFCE_dp24 has been suspended successfully
Dec 1 10:26:11 TServer /usr/bin/x2goresume-session: client 10.32.14.29 has successfully resumed session with ID x2gotest-50-1417418483_stDXFCE_dp24
Dec 1 10:26:12 TServer /usr/bin/x2gomountdirs[14715]: WARNING: mounting of /home/it-user/.x2go/S-x2gotest-50-1417418483_stDXFCE_dp24/spool failed
Dec 1 10:26:12 TServer /usr/bin/x2gosetkeyboard: Setting X keyboard according to /home/x2gotest/.x2go/C-x2gotest-50-1417418483_stDXFCE_dp24/keyboard
Dec 1 10:26:40 TServer /usr/lib/cups/backend/cups-x2go[15008]: Print job received from cups -> 3 x2gotest Безымянный1 1 PageSize=A4 Resolution=600dpi job-uuid=urn:uuid:e6ce85f0-b3f8-3951-69d1-0c9c78f8c87c job-originating-host-name=localhost time-at-creation=1417418800 time-at-processing=1417418800
Dec 1 10:26:40 TServer /usr/bin/x2goprint[15033]: x2goprint is processing /var/spool/x2goprint/x2gotest-50-1417418483_stDXFCE_dp24_3-x2gotest-cupsjob15008.pdf with print job title ,,Безымянный1''
Dec 1 10:29:12 TServer /usr/bin/x2gosuspend-session: session with ID x2gotest-50-1417418483_stDXFCE_dp24 has been suspended successfully
Склоянюсь к тому, что чему то не хватает прав, но чему? (Читал, что многие писали - работает из коробки, пробовал много на чем, везде такая пробема...)
Bedazzled
ОС: ubuntu
Re: x2go
Сообщение Bedazzled »
порты стандартные?
попробуйте создать нового пользователя и проверить под ним.
если есть возможность отправте мне в личку данные для подключения БЕЗ прав админа.
rootsergio
Re: x2go
Сообщение rootsergio »
Rosinka32 писал(а):
01.12.2014 10:50
Вам необходимо добавить пользователя в группу fuse, чтобы он мог печатать и пробрасывать каталоги
Bedazzled
ОС: ubuntu
Re: x2go
группа fuse тут непричём., даже у себя на сервере перепроверил, не один пользователь туда не добавлен. И насколько я знаю этот вопрос автор решил.
DjSpike
Статус: в поисках истины
ОС: Lubuntu 12.04
Re: x2go
Сообщение DjSpike »
Кто-нибудь на Ubuntu 14.04 пробовал x2go как он работает ?
rootsergio
Re: x2go
Bedazzled писал(а):
25.12.2014 16:28
Подскажите пожалуйста, каким образом у вас настроен проброс каталогов и печать. У меня без добавления в группу fuse пользователей не получалось.
Система Debian 7.7, XFCE, x2go ver 4.0.1.18
Bedazzled
ОС: ubuntu
Re: x2go
rootsergio писал(а):
26.12.2014 08:41
Bedazzled писал(а):
25.12.2014 16:28
я просто создаю нового пользователя и всё, не в какие группы не добвляю..система ubuntu 12.04, про Debian не скажу.
yurykom
Re: x2go
Сообщение yurykom »
Всем здравствуйте! Помогите, пожалйста, разобраться. На ubuntu 14.04 установил 1с8.3, файловый вариант, версия для linux (без вайн). Работает без проблем.
Установил х2go. И вот в нем 1с-ка запускается, но после выбора базы, ничего не происходит. Если запускать из терминала 1сv8, то пишит "Segmentation fault" и отваливается. В чем может быть дело?
Re: x2go
yurykom писал(а):
03.01.2015 20:42
В быдлокоде.
На Вашей стороне это не исправить, пробивайтесь к поддержке 1С.
yurykom
Re: x2go
Сообщение yurykom »
yurykom писал(а):
03.01.2015 20:42
В быдлокоде.
Так вроде в этой теме были описаны подобные рабочие связки. У людей-то как-то работает?
Re: x2go
Ключевое слово - "исправить". Обойти, может быть, и можно.
Bedazzled
ОС: ubuntu
Re: x2go
yurykom писал(а):
03.01.2015 20:42
попробуйте платформу 1с 8.3.4.496.
оболочка какая используется?
yurykom
Re: x2go
Сообщение yurykom »
Bedazzled писал(а):
04.01.2015 08:14
8.3.5.1383, УНФ 1.5.2.31
я думал, что с правами что-то не то. туда-сюда менял. ничего не заработало. Сегодня перестало работать и без терминала. Пишет Segmentation fault. Значит дело в правах? Какие должны стоять права?
Bedazzled
ОС: ubuntu
Re: x2go
сначало вам нужно 1с до ума довести:)
права на что?
если на папку с базой то раз
два
К сожалению, пришлось всё-таки вставить один «костыль». Без комментариев.
/etc/crontab:
# Ногами не пинать!!! 1С - [censored] [censored] [censored], которое игнорирует umask.
* 8-21 * * *    root chmod -R g+rw /srv/Storage
источник
http://habrahabr.ru/post/244703/
yurykom
Re: x2go
Сообщение yurykom »
Bedazzled, спасибо за участие. Выяснил, что перестало запускаться не из-за прав скорей всего. После перезагрузки, почему-то интерфейс поменялся на английский. Поменял обратно на русский и снова 1с стала запускаться! Мистика какая-то. Может в терминале и не запускается из-за английского интерфейса. У меня КДЕ, Xfce и др открывается в английском интерфейсе. Как сделать так, чтоб в русском открывался?
yurykom писал(а):
04.01.2015 10:09
В общем мистика продолжается. Теперь интерфейс в терминале на русском и 1с открывается! Ничего не понял, но все работает )
Bedazzled
ОС: ubuntu
Re: x2go
используйте kde
у меня в подписи указана ссылка на самые распространеные вопросы по x2go
бывало еще у некоторых пользователей интерфейс становился английским для исправления нужно в файле ~/.pam_environment оставить только:
LANGUAGE=ru:en
LANG=ru_RU.UTF-8
Re: x2go
yurykom писал(а):
04.01.2015 09:03
Нет, дело в кривом коде.
википедия://ошибка сегментации
L_S_V
Re: x2go
Сообщение L_S_V »
а как запускать этот x2go?
у меня в генту есть скрипт
/etc/init.d/x2gocleansessions
но запустив его у меня не работает NX.
Может есть другий скрипт запуска?
вообще есть вот такие исполняемые файлы после установки:
# ls /usr/*bin/*x2go*
/usr/bin/x2gobasepath        /usr/bin/x2gomountdirs              /usr/bin/x2gosuspend-agent
/usr/bin/x2gocmdexitmessage  /usr/bin/x2gopath                   /usr/bin/x2gosuspend-session
/usr/bin/x2gofeature         /usr/bin/x2goprint                  /usr/bin/x2goterminate
/usr/bin/x2gofeaturelist     /usr/bin/x2goresume-session         /usr/bin/x2goterminate-session
/usr/bin/x2gofm              /usr/bin/x2goruncommand             /usr/bin/x2goumount-session
/usr/bin/x2gogetapps         /usr/bin/x2goserver-run-extensions  /usr/bin/x2goversion
/usr/bin/x2gogetservers      /usr/bin/x2gosessionlimit           /usr/sbin/x2gocleansessions
/usr/bin/x2golistdesktops    /usr/bin/x2gosetkeyboard            /usr/sbin/x2godbadmin
/usr/bin/x2golistmounts      /usr/bin/x2gostartagent             /usr/sbin/x2golistsessions_root
/usr/bin/x2golistsessions    /usr/bin/x2gosuspend                /usr/sbin/x2goshowblocks
L_S_V
Re: x2go
Сообщение L_S_V »
решил, имя хоста поменял с localhost на другое и заработало.
oldbay
ОС: gentoo, cenos
Re: x2go
Сообщение oldbay »
L_S_V писал(а):
13.01.2015 14:34
На предыдущей версии на генте x2goserver работал и с localhost-ом но с 4.0.1.12 то ли с 4.0.1.18 перестал
У меня другой вопрос ребром встал:
на клиенте у пользователей win xp или 7(без разницы) версия клиента 4.0.3.0
на сервере gentoo версия сервера x2goserver-4.0.1.18-r1
Проблемма с использованием кириллических паролей (доменных юзеров) - не проходит аторизация(причём толко с клиента x2go - у putty и winscp такой беды не наблюдается).
Можно конечно решить вопрос при помощи публикации dsa ключей. Но у нас предусмотрена самопубликация - и по иструкции первый вход должен быть произведен пользователем под доменным паролем :(. Сервер в АДъ, естественно, заведен.
Ошибка x2go client стандартная для неверного пароля: "Access denied" и всё тут, в логах ssh сервера тоже всё стандартно: error: PAM: Authentication failure
Кто нибудь с подобной прблеммой сталкивался?
Bedazzled
ОС: ubuntu
Re: x2go
oldbay писал(а):
21.01.2015 09:02
L_S_V писал(а):
13.01.2015 14:34
чтобы в будущем небыло похожих проблем не используйте кирилицу в паролях:)
Lorte
Re: x2go
Сообщение Lorte »
oldbay писал(а):
21.01.2015 09:02
Вообще на будущее: в системах Линукс использование кириллических логинов и паролей - одно из больных мест: где-то прокатывает, где-то нет. Так что только латиница и цифры.
oldbay
ОС: gentoo, cenos
Re: x2go
Сообщение oldbay »
Ну воот, а так хотелось .... :)
Кириллические пароли это не моя прихоть - и они не в Линукс
Проблема с использованием кириллических паролей (доменных юзеров)
А сервер с x2go заведен в этот же домен и использует доменную авторизацию для терминальных сессий пользователей.
АД не моя сфера отвественности - а во внутренних правилах и инструкциях нет никаких ограничений на кириллицу в паролях или логинах :(
Так и живём....
oermolaev
Re: x2go
Сообщение oermolaev »
oldbay писал(а):
22.01.2015 08:57
Введите. Напишите докладную записку о необходимости добавления этого пункта в инструкции. Бумага - сильная вещь! Особенно правильно оформленная и зарегистрированнная
oldbay
ОС: gentoo, cenos
Re: x2go
Сообщение oldbay »
oermolaev писал(а):
22.01.2015 16:07
Увы и ах, эти докладные будут касаться деятельности другой службы и приняты к рассмотрению не будут: тоже особенности внутренней бюрократии
ex_trin
Re: x2go
Сообщение ex_trin »
Подскажите как можно сделать чтобы при подключении сразу запускался virt-manager.
Сейчас подключаюсь выбрав с свойствах "Удаленные приложения", затем открываю окно выбора приложений, из списка выбираю virt-manager и запускаю. - долго
пробовал в свойствах подключения указать "приложение" и в путь "/usr/lib/virt-manager" - в результате соединение все время сбрасывается
Bedazzled
ОС: ubuntu
Re: x2go
попробуйте через скрипт
achilles85
ОС: Ubuntu 12.04 LTS; Win 7
Re: x2go
Сообщение achilles85 »
Bedazzled писал(а):
14.11.2014 15:07
achilles85 писал(а):
19.08.2014 11:37
Не могу найти решение проблемы. Юзеры ходят в инет через x2go сервер. Клиент настроен так, чтобы пользователь ввел логин и пароль (никакие настройки в окне клиента ему не доступны), после открывается файрфокс в рутлесс режиме. Все работает отлично. НО!! стоит закрыть окно клиента закрывается и файрфокс. Заново логиниться не получается потому, что сессия висит и не продолжается. Приходится в настройках ставить гном(пример), логиниться и затем появится окошко с выбором завершения сессии. Как обойти эту проблему?
в последней версииx2goclient добавили пунк в раздел оболочки "веб-браузер" , проверил ка краз то что вам нужно, при конекте будет открываться только фаервфокс и при его закрытии завершается сесия.
В самом деле, если выбрать приложением веб-браузер, то некоректно закрытую сессию клиент сам предлагает завершить. Я ж прописал вместо вэб-браузера путь к скрипту, в котором прописан ярлык для запуска файерфокса+раскладка клавы.
Как узнать каким файлом запускается браузер при выборе опции "вэб-браузер"? Если в него прописать раскладку клавы, думаю проблема будет решена
Bedazzled
ОС: ubuntu
Re: x2go
если смотреть в конфиг сеcсии то там :
command=WWWBROWSER
я думаю можно прописать путь к вашему скрипту в файле
if [ "$cmd" == "WWWBROWSER" ]; then
if [ -e "/usr/bin/"ВАШСКРИПТ"" ]; then
fi
http://code.x2go.org/doc/x2goserver/man/ma...ncommand.8.html
http://x2go-dev.x2go.narkive.com/msYimvem/...go-applications
oldbay
ОС: gentoo, cenos
Re: x2go
Сообщение oldbay »
Продолжу тематику печати.
Долгими и упорными мучениями заставил работать cups backend для cups-x2go в gentoo. Отредактированный для генты бэкенд и прочее окружение здесь:
cups_x2go.tar.bz2
(7.14 КБ) 37 скачиваний
Теперь есть проблема со стороны клиента... вернее не проблема - а моя некомпетентность: Клиент должен передавать, полученный через примонтированный спулер, pdf файл на внешнюю софтину для печати. В никсах проблем нет: все решается стандартными утилитами. На виндовых клиентах стал передавать печать gsprint-у от Ghostgum-а, но в процессе печати выскакивает консоль пугающая юзеров до коликов (думают что какой то системный сбой или вирус). Вопрос: есть ли в для винды аналог gsprint-а, но полностью в графике, очень желательно, не требующей административных прав при установке.
Ответить
