Как настроено? Конфиг в студию. Сервис включён?
Перегревается процессор.
- Bizdelnick
Re: Перегревается процессор.
@debian:~$ cat /etc/cpufreqd.conf
# this is a comment
# see CPUFREQD.CONF(5) manpage for a complete reference
# Note: ondemand/conservative Profiles are disabled because
# they are not available on many platforms.
[General]
pidfile=/var/run/cpufreqd.pid
poll_interval=2
verbosity=4
#enable_remote=1
#remote_group=root
[/General]
#[acpi]
#acpid_socket=/var/run/acpid.socket
#[/acpi]
#[nforce2_atxp1]
#vcore_path=/some/path
#vcore_default=1500
#[/nforce2_atxp1]
#[sensors_plugin]
#sensors_conf=/some/file
#[/sensors_plugin]
[Profile]
name=On Demand High
minfreq=40%
maxfreq=100%
policy=ondemand
[/Profile]
[Profile]
name=On Demand Low
minfreq=20%
maxfreq=80%
policy=ondemand
[/Profile]
[Profile]
name=Performance High
minfreq=100%
maxfreq=100%
policy=performance
#exec_post=echo 8 > /proc/acpi/sony/brightness
[/Profile]
[Profile]
name=Performance Low
minfreq=80%
maxfreq=80%
policy=performance
[/Profile]
[Profile]
name=Powersave High
minfreq=60%
maxfreq=60%
policy=powersave
[/Profile]
[Profile]
name=Powersave Low
minfreq=40%
maxfreq=40%
policy=powersave
[/Profile]
#[Profile]
#name=Conservative High
#minfreq=33%
#maxfreq=100%
#policy=conservative
#[/Profile]
#[Profile]
#name=Conservative Low
#minfreq=0%
#maxfreq=66%
#[/Profile]
# Basic states
# when AC use performance mode
[Rule]
name=AC Rule
ac=on # (on/off)
profile=Performance High
[/Rule]
# stay in performance mode for the first minutes
[Rule]
name=AC Off - High Power
ac=off # (on/off)
battery_interval=70-100
#exec_post=echo 5 > /proc/acpi/sony/brightness
profile=Performance Low
[/Rule]
# conservative mode when not AC
[Rule]
name=AC Off - Medium Battery
ac=off # (on/off)
battery_interval=30-70
#exec_post=echo 3 > /proc/acpi/sony/brightness
profile=Powersave High
[/Rule]
[Rule]
name=AC Off - Low Battery
ac=off # (on/off)
battery_interval=0-30
profile=Powersave Low
[/Rule]
# Special Rules
# CPU Too hot!
[Rule]
name=CPU Too Hot
acpi_temperature=55-100
cpu_interval=50-100
[/Rule]
# use performance mode if I'm watching a movie
# I don't care for batteries!
# But don't heat too much.
[Rule]
name=Movie Watcher
programs=xine,mplayer,gmplayer
battery_interval=0-100
acpi_temperature=0-60
cpu_interval=0-100
[/Rule]
Это(то, что ниже) до перезагрузки:
@debian:~$ su
Пароль:
root@debian:~# cpufreq-set --governor ondemand --cpu 1
root@debian:~# cpufreq-set --governor ondemand --cpu 0
root@debian:~# exit
exit
alex@debian:~$ cat /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
ondemand
alex@debian:~$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
ondemand
~# cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: powernow-k8
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 1000 ns.
hardware limits: 1000 MHz - 2.00 GHz
available frequency steps: 2.00 GHz, 1000 MHz
available cpufreq governors: userspace, conservative, powersave, ondemand, performance
current policy: frequency should be within 2.00 GHz and 2.00 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency is 2.00 GHz (asserted by call to hardware).
cpufreq stats: 2.00 GHz:100,00%, 1000 MHz:0,00%
analyzing CPU 1:
driver: powernow-k8
CPUs which run at the same hardware frequency: 1
CPUs which need to have their frequency coordinated by software: 1
within this range.
В /etc/modules
~# cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Parameters can be specified after the module name.
firewire-sbp2
loop
powernow-k8
cpufreq_ondemand
В памяти:
root@debian:~# lsmod|grep powernow
powernow_k8 17618 0
mperf 12453 1 powernow_k8
processor 8157 1 powernow_k8
А автозагрузке:
debian:/etc/init.d$ ls
loadcpufreq
cpufreqd sysfsutils
cpufrequtils
После перезагрузки:
root@debian:~# cpufreq-info
analyzing CPU 0:
driver: powernow-k8
The governor "performance" may decide which speed to use
within this range.
analyzing CPU 1:
driver: powernow-k8
within this range.
Проблему решил так:
закоментировал в /etc/cpufreqd.conf все режимы, кроме ondemand, после выполнил это:
перезагрузил, изменениия сохранились:
ondemand
ondemand
Спасибо всем за помощь, буду считать, что проблема решена.
Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.35-2 x86_64 GNU/Linux
