Обсуждаем Linux Mint (кто что может сказать - впечатления)
- ОС: LinuxMint7/Debian Lenny
Re: Обсуждаем Linux Mint
Единсвенное чем для меня удобен Mint и почему я решил остановиться на нем это установка кодеков в несколько кликов и предустановка некторых прог которых нет в ubuntu. Ну что поделать лень мне ковырять sources.list и добавлять репы medibuntu))) А так большой разницы я не заметил.
- ОС: Ubuntu
Пока запущена фаза тестирования. Подробнее на оффтопе - http://www.linuxmint.com/blog/?p=841
Ждем-с.
- ОС: Ubuntu
Осталось буквально пара дней до релиза
I can see that’s the question on everybody’s lips right now.. “when is Mint 7 going to be released?”. You probably saw on twitter that LinuxMint-7-DEV-052.iso was approved by Exploder and that it passed all the tests… and yet, no sign of it in the mirrors and no announcements on the website
I just want to ask the community for a little more patience. There’s very little left to do before the release but we can’t afford to skip any steps.
- LinuxMint-7-DEV-052.iso wasn’t fully tested by myself, and although it was maintained by me and approved by Exploder, I still want to make sure about a few things before I approve it myself.
- The Universal edition is going to be released at the same time as the Main edition, so that needs to get approved as well. I’m testing LinuxMint-7-Universal-DEV-007.iso right now. It looks good but I need to make sure it passes all the tests and that it’s easily upgradable to a Main Edition with a single click of the mouse.
- The User Guide needs to be updated and that will take a day or two.
- Once everything is fine, it will take up to 48 hours for the ISOs to propagate on the download mirrors.
After that, we’ll be ready for a release.
The upgrade path from Mint 7 RC1 is working fine. The upgrade path from Mint 6 will need to be tested and the upgrader will eventually need to be updated. This won’t hold the release though and we’ll make an announcement for Mint 6 users a few days after the release.
Please be patient and my apologies for the time this is taking.
- ОС: Ubuntu
Есть семерка! Официально релиз еще не объявлен, но на фтп уже появилось. Так что делаем на раз-два-три:
Заходим http://www.linuxmint.com/edition.php?id=38
Выбираем зеркало и идем туда
На фтп поднимаемся выше по каталогу и заходим в раздел /stable
Там исошник и забираем
Радуемся!
Радуемся!
- ОС: Linux Mint 7
Кто пробовал отпишитесь что да как, а то убунту/кубунту 9.04 не порадовал ни разу... Может тут что подлатали? Особенно интересует поведение звука с пульсаудио.
- ОС: Linux Mint 7
Все нормально работает, новая тема Shiki Mint радует глаза
со звуком проблем нет, все как обычно определилось из коробки
Заманчиво, скачаем поглядим
- Статус: Еще один красноглазик
Недавно наткнулся на такую версию дистрибутива: Linux Mint 7 - Universal Edition. Так вот кто знает чем эта версия отличается от обычной Linux Mint 7?
AMD Athlon 3200+ 2.Ghz, RAM 1g, I/Video, 80g IDE
Intel Dual-Core E5300 2.6 GHz RAM 4 GB DDR2, NVIDIA GeForce 7600 GS 256 MB, HDD 320 GB IDE
Intel i3 3.4 GHz, RAM 4 GB DDR3, NVIDIA GeForce 220 GT 512 MB, HDD 500 GB SATA2
Блог: http://admi0n.blogspot.com/
- ОС: Vista end ubuntu
Если память мне не отшибает, то этот дистрибутив предназначен для стран, где жесткие ограничения на несвободное ПО, такие например как кодеки и т.д. То есть в отличие от обычного дистрибутива в нем нет предустановленных кодеков
Скорее всего наоборот, потому как размер больше, и языковых пакетов больше насколько известно мне.
- ОС: Ubuntu + Debian stable
x-peremental писал(а): ↑03.06.2009 10:43Скорее всего наоборот, потому как размер больше, и языковых пакетов больше насколько известно мне.
Не...
Universal edition "aims to provide the same features as the Main Edition without including proprietary software, patented technologies or support for restricted formats."
Так что размер больше скорее всего из-за включенных языковых пакетов.
Nothing comes from nothing
- ОС: Linux Mint 5 Elyssa
Поставил mint
ну вообщем сначала была версия ядра 2,16 потом поднял до 2.5 первое впечатление неплохое, привиду сравнение,
Т,К, у меня ноут дрова вообщем сложнее искать дак вот WINDOWS нашла 1/9 дров от всех а linux 99/100 примерно единственное что у меня не рабило это дрова на nvidia mobile (в смысле мобильные видюхи) но это было устранено сразу, пока что небыло определенно ни одного бага
user@host
user@user ~ $ cat /etc/issue
Linux Mint 5 Elyssa \n \l
user@user ~ $ uname -a
Linux petka 2.6.24-24-generic #1 SMP Wed Apr 15 15:54:25 UTC 2009 i686 GNU/Linux
сначала юзай Googlec А потом спрашивай на форуме. ,
- ОС: Ubuntu 9.04 / Slackware 12.2
Захвалили, решил поставить. Для начала на виртуалку..
UPD Локализация подвела.. Русификация неполная или я чего-то недоглядел..
GNU/Linux
- Ubuntu 9.04, kernel 2.6.28.13
- Slackware 12.2, kernel 2.6.27.7
- Mandriva 2009 Flash, kernel 2.6.27.14
- ОС: OpenSuse 11.4
Каюсь, наговорил на дистрибутив.. Надо было прежде нормально его локализовать..
GNU/Linux
У меня тоже на Минте 7 проблема с видео драйверами (на Mobile Intel 965 Express). Ставил с версии 97 и выше и все бестолку, ускорение так и не включается. Пробовал ставить и Убунту 9.04 и PuppyLinux. Я где то натыкался ни информацию, что это косяк в Убунту 9.04 ну естественно все производных дистрибутивах.
starik писал(а): ↑07.06.2009 19:12У меня тоже на Минте 7 проблема с видео драйверами (на Mobile Intel 965 Express). Ставил с версии 97 и выше и все бестолку, ускорение так и не включается. Пробовал ставить и Убунту 9.04 и PuppyLinux. Я где то натыкался ни информацию, что это косяк в Убунту 9.04 ну естественно все производных дистрибутивах.
проблема в том что nvidia зажимает изначально дрова и сама их производит не давая их корректировать.
когда я себе станавливал драйвера он мне выдала сообщение типо это закрытые дрова хотите ли вы их установить?
попробуй не через synaptic и apt-get а в панели там есть закладка типо драйвераи устройства точно не помню. у меня через туда все проканало.
- ОС: OpenSuse 11.4
Скажите, может видели или слышали, будет ли Минт 7 на КДЕ, очень бы хотелось посмотреть.
что нового в mint 7
там чотко и ясно написано что mint 7 выбирает в стандартном пакете gnome.
эта ссылка на дистрибы с разными рабочими столами Community Editions of Linux Mint
посмотри еще тут о поддержке kde felicia kde к сожалению пока есть дистриб c kde linux mint 6 извини обрадовать не могу! но кто нам мешает установить вручную? а насчет выхода насколько я понял будет mint 7 c kde.
а у меня там только драйвер диска предлагает активировать и он нормально активируется, но видео драйвера там нет, хотя в Минт 5 и шестом он предлагал поставить, хотя ей (системе) это не удавалось. Ввиду чего приходилось пользоватся утилитой ENVY а сейчас и она не помогает
- ОС: Linux Mint
С драйверами все нормально. Compiz не работает.
Учим Compiz в Ubuntu 9.04 работать со встроенным видеоадаптером Intel:
http://xand.net.ru/os/linux/stati-linux/uc...dapterom-intel/
- ОС: archlinux
Ниччего не понял. "Language support" - это оно? Поставил русский, пакеты доставились, но ни одной русской буквы от этого не прибавилось. (Скрин прилагается :S ) Ну разве что в опенофисе выбор появился, и там действительно стало можно включить русский интерфейс.
Но это я на флешку ставлю. Вот по этой инструкции.
(Да, это у меня семёрка, я просто обоину поменял)
- ОС: archlinux
А! Всё. Дошло.
Ну то есть не то чтобы понял, но перезагрузился - и всё применилось.
чего и следовало ожидать правда можно было без общей перезагрузки mint просто перезагрузить Gnome. Сколько на Linuxe сидишь?
Всем доброе вермя суток.
Вот может мне кто то сказать для чего в 7 Минте понапихали столько проигрывателей Тотем, МПлеер, Гноме МПлеер, Ритмбокс.
Для этого были какие то особые причины или просто для того что бы оставить кому, что нравится? Остальное поудалять?
я не слышал особых причин для такой темы
кстати как ощущения после 7 что нового ? какие баги заметили? можно на нее переходить?
Плохого ничего не скажу, но внешне ничего особо нового, отличающегося от Убунту 9.04 тоже не появилось. Убунту 6 в этом плане была поинтересней.
- ОС: OpenSuse 11.4
Вышел первый релиз кандидат Mint 7 KDE
