конкретно про GPRS/EDGE/3G/CDMA/EvDO модемы
Brainenjii
ОС: OpenSuSE 10.3
Re: конкретно про GPRS/EDGE/3G/CDMA/EvDO модемы
Сообщение Brainenjii »
Модем ZTE, определяется как
scsi 5:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 0
Но. при этом. в lsusb его нет... ИМХО, основная проблема в этом
udevadm --monitor
генерит уйму текста, но мне совершенно не понятного ^_^
Hut:/home/hut# udevmonitor udevmonitor prints the received event from the kernel [UEVENT] and the event which udev sends out after rule processing [UDEV] UEVENT[1230689281.021628] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.0 UEVENT[1230689281.021659] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.1 UEVENT[1230689281.021667] remove@/class/usb_endpoint/usbdev5.9_ep03 UEVENT[1230689281.021673] remove@/class/usb_endpoint/usbdev5.9_ep83 UEVENT[1230689281.021679] remove@/class/scsi_generic/sg2 UEVENT[1230689281.021685] remove@/class/scsi_device/6:0:0:0 UEVENT[1230689281.021691] remove@/class/scsi_disk/6:0:0:0 UEVENT[1230689281.021697] remove@/block/sdc UEVENT[1230689281.021703] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.2/host6/target6:0:0/6:0:0:0 UEVENT[1230689281.021710] remove@/class/scsi_host/host6 UDEV [1230689281.023000] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.0 UEVENT[1230689281.023243] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.2 UEVENT[1230689281.023253] remove@/class/usb_endpoint/usbdev5.9_ep84 UEVENT[1230689281.023260] remove@/class/usb_endpoint/usbdev5.9_ep85 UEVENT[1230689281.023266] remove@/class/usb_endpoint/usbdev5.9_ep04 UEVENT[1230689281.023272] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.3 UEVENT[1230689281.023278] remove@/class/usb_device/usbdev5.9 UEVENT[1230689281.023284] remove@/class/usb_endpoint/usbdev5.9_ep00 UEVENT[1230689281.023290] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3 UDEV [1230689281.023673] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.1 UDEV [1230689281.024736] remove@/class/usb_endpoint/usbdev5.9_ep03 UDEV [1230689281.025735] remove@/class/usb_endpoint/usbdev5.9_ep83 UDEV [1230689281.026603] remove@/class/scsi_generic/sg2 UDEV [1230689281.027582] remove@/class/scsi_device/6:0:0:0 UDEV [1230689281.028485] remove@/class/scsi_disk/6:0:0:0 UDEV [1230689281.029410] remove@/block/sdc UDEV [1230689281.033352] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.2/host6/target6:0:0/6:0:0:0 UDEV [1230689281.035461] remove@/class/scsi_host/host6 UDEV [1230689281.036767] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.2 UDEV [1230689281.037780] remove@/class/usb_endpoint/usbdev5.9_ep84 UDEV [1230689281.038767] remove@/class/usb_endpoint/usbdev5.9_ep85 UDEV [1230689281.039620] remove@/class/usb_endpoint/usbdev5.9_ep04 UDEV [1230689281.040470] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.3 UDEV [1230689281.041495] remove@/class/usb_device/usbdev5.9 UDEV [1230689281.042463] remove@/class/usb_endpoint/usbdev5.9_ep00 UDEV [1230689281.043388] remove@/devices/pci0000:00/0000:00:1d.7/usb5/5-3 UEVENT[1230689294.247016] add@/devices/pci0000:00/0000:00:1d.7/usb5/5-3 UEVENT[1230689294.247046] add@/class/usb_endpoint/usbdev5.10_ep00 UDEV [1230689294.253852] add@/devices/pci0000:00/0000:00:1d.7/usb5/5-3 UEVENT[1230689294.254069] add@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.0 UDEV [1230689294.254675] add@/class/usb_endpoint/usbdev5.10_ep00 UEVENT[1230689294.254954] add@/class/scsi_host/host7 UDEV [1230689294.255302] add@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.0 UEVENT[1230689294.260500] add@/class/usb_endpoint/usbdev5.10_ep01 UEVENT[1230689294.260516] add@/class/usb_endpoint/usbdev5.10_ep81 UEVENT[1230689294.260522] add@/class/usb_device/usbdev5.10 UDEV [1230689294.304405] add@/class/scsi_host/host7 UDEV [1230689294.306048] add@/class/usb_endpoint/usbdev5.10_ep01 UDEV [1230689294.307429] add@/class/usb_endpoint/usbdev5.10_ep81 UDEV [1230689294.313090] add@/class/usb_device/usbdev5.10 UEVENT[1230689299.264786] add@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.0/host7/target7:0:0/7:0:0:0 UDEV [1230689299.265345] add@/devices/pci0000:00/0000:00:1d.7/usb5/5-3/5-3:1.0/host7/target7:0:0/7:0:0:0 UEVENT[1230689299.305528] add@/block/sr0 UEVENT[1230689299.305546] add@/class/scsi_device/7:0:0:0 UEVENT[1230689299.305553] add@/class/scsi_generic/sg2 UDEV [1230689299.307587] add@/class/scsi_device/7:0:0:0 UDEV [1230689299.315964] add@/class/scsi_generic/sg2 UDEV [1230689299.361282] add@/block/sr0
Это на вытыкание и втыкание модема... В общем, подскажите, в чём проблема может быть?
    (\_(\
∞ ( o.0)   ∞
    (")__(")
broom
Статус: мизантроп.ка
Сообщение broom »
Brainenjii писал(а):
31.12.2008 02:10
Это вы где такую запись наблюдаете, в каком логе?
31.12.2008 02:10
нашлось блочное устройство /dev/sr0.
В теме, ссылка на которую уже давалась, про модемы ZTE написано, что если сделать eject sr0, то он должен перестать быть cd-ромом и перейти в режим модема.
подробнее в этом сообщении, если у вас ZTE MF622 - комплект Beeline Internet Дома
Brainenjii
ОС: OpenSuSE 10.3
Эта строчка проглядывала в dmesg'e
Про eject /dev/sr0 читал, и modprobe делал - но не помогало Т_Т Т.е. /dev/sr0 пропадало, но ttyUSB не появлялось... Ещё этот же модем определялся как /dev/sg1 почему-то, там было написано ZTE и Direct-access вместо CDROM (сейчас сижу под виндой и вообще в армии, так что процитировать точно не смогу Т_Т)
Ядро обновил до 2.6.24 (было 2.6.18) но, опять же, не помогло Т_Т
P.S. так, разобрался, строчка про scsi 5:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 0 появляется после
modprobe usbserial vendor=0x19d2 product=0x0001
т.е. сидиром все-таки меняется, но не на модем, а на MMC... Щас попробую ещё разок ^_^
    (\_(\
∞ ( o.0)   ∞
    (")__(")
broom
Сообщение broom »
а модель-то модема какая? ZTE MF622 или другая?
Brainenjii
ОС: OpenSuSE 10.3
Не совсем - ZTE MF626...
    (\_(\
∞ ( o.0)   ∞
    (")__(")
broom
Сообщение broom »
01.01.2009 01:13
Не пойму я никак, вы тему-то всю удосужились прочитать? Несколько человек отписывалось по поводу этого модема. Вот, например, подходящее правило для udev: комплект Beeline Internet Дома
ProductID там другой.
Brainenjii
ОС: OpenSuSE 10.3
Это я уже нашёл, но тоже не помогло ^_^ Вообще, про разные модели только сейчас узнал - раньше думал есть только хуавэй или ZTE, а тут оказывается ZTE разные бывают ^_^ Теперь нашёл http://forum.ubuntu.ru/index.php?topic=39060.0 и щас качаю исходники ядра ^_^
Кстати с Новым Годом всех ^_^
UPD: Ух, если действительно как новый год встретишь, то так его и проведёшь, то служба у меня будет просто потрясающая ^_^ Правда шанс небольшой Т_Т
В общем... Добил я таки этот /dev/ttyUSB0 через
eject /dev/sr0 &&modprobe -r usbserial&&modprobe usbserial vendor=0x19d2 product=0x0031
Теперь cat /proc/bus/usb/devices выдаёт:
...skipped...
T: Bus=05 Lev=02 Prnt=03 Port=01 Cnt=01 Dev#= 17 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=19d2 ProdID=0031 Rev= 0.00
S: Manufacturer=ZTE, Incorporated
S: Product=ZTE CDMA Technologies MSM
S: SerialNumber=1234567890ABCDEF
C:* #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 0 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 1 Alt= 1 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=usbserial_generic
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
...skipped...
Выделенное смущает - как читал где-то уже не помню где, там должно быть usbfs вместо none... Собственно, это главное что смущает на данный момент... Сейчас wvdial с конфигом:
[Dialer Defaults]
Username = beeline
Password = beeline
Init1 = "ATZ"
Init2 = "ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0"
Init3 = "AT+CGDCONT=1,\"IP\",\"home.beeline.ru\""
Phone = *99***1#
Modem Type = USB Modem
Stupid Mode = 0
Idle Second = 300
Auto DNS = 1
Dial Command = ATDT
Modem = /dev/ttyUSB0
ISDN = 0
Baud = 460800
New PPPD = yes
пытается звонить и даже вроде бы получает баланс 0.о Но почти уверен, что это из-за неправильных init1 и init2 - тут стоят для телефона... А вот отсутствие этого самого usbfs сильно тревожит - читал (тут - http://ru.gentoo-wiki.com/wiki/MF626), что без двух /dev/ttyUSB соединение будет рвать каждые 2 минуты... В общем, подскажите, как получить этот самый usbfs
UPD: так, добавил Carrier Check = no в /etc/wvdial.conf - вроде дело чуть-чуть сдвинулось!
("Новый /etc/wvdial.conf") писал(а):[Dialer Defaults]
Username = beeline
Password = beeline
Init1 = "ATZ"
Init2 = "AT+CGDCONT=1,\"IP\",\"home.beeline.ru\""
Phone = *99***1#
Stupid Mode = 1
Carrier Check = no
Idle Second = 300
Auto DNS = 1
Dial Command = ATDT
ISDN = 0
Baud = 460800
New PPPD = yes
Вот что выводит wvdial -
Hut:/home/hut# wvdial
--> WvDial: Internet dialer version 1.56
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: ATZ
ATZ
OK
--> Sending: AT+CGDCONT=1,"IP","home.beeline.ru"
OK
--> Modem initialized.
--> Sending: ATDT*99***1#
--> Waiting for carrier.
ATDT*99***1#
CONNECT
--> Carrier detected. Starting PPP immediately.
--> Starting pppd at Thu Jan 1 21:37:15 2009
--> Pid of pppd: 4338
--> pppd: HпїЅпїЅпїЅпїЅ[11][06][08]пїЅ [06][08]
--> Using interface ppp0
И ещё до кучи tail /var/log/messages -
--> Sending: ATZ
ATZ
OK
OK
ATDT*99***1#
CONNECT
Вроде уже похоже на дело! Когда через телефон коннекчусь, команды навроде pppd: HпїЅпїЅпїЅпїЅ[11][06][08]пїЅ [06][08] бегут постоянно, а тут - зависают... В чем может быть дело?
    (\_(\
∞ ( o.0)   ∞
    (")__(")
Brainenjii
ОС: OpenSuSE 10.3
Попробовал навставлять в init'ы комманд с http://ru.gentoo-wiki.com/wiki/MF626 - получилось вот это вот - http://paste.org.ru/?k70zmc
Но дальше дело все-равно не пошло >_< А надо очень-очень... Подскажите, в чем проблема, 4 день уже мучаю >_<
    (\_(\
∞ ( o.0)   ∞
    (")__(")
mexx2
ОС: OpenSuSe 11.0 i586
Сообщение mexx2 »
Goodvin писал(а):
25.11.2008 18:25
Я тут, кажется, нашел решение.
После 4 дней упорного рытья по буржуйским форумам вычитал, что для моей модели модема нужна программа HSOConnect.
Инсталляция её на openSUSE не совсем тривиальна, но вроде как есть подвижки в лучшую сторону.
Модем вроде как стал виден и вроде как показывает уровень сигнала и режим 3G.
Выхода в интернет пока нет, буду рыть дальше.
Подробности тут (на буржуйском наречии):
http://www.linuxportalen.se/forums/2008/11...-11-r-ttigheter
http://www.pharscape.org/component/option,...viewforum/f,15/
http://www.pharscape.org/component/option,...e7a4fa73e5f491/
http://www.pharscape.org/component/option,...iewtopic/t,588/
update:
Программа модем видит, показывает уровень сигнала, режим "3G" и прочие прелести.
Но при попытке коннекта машина вешается наглухо.
Боремся дальше.
Здравствуйте!
С праздниками Вас поздравляю!
Недавно,а точнее 2.01.09 стал одним из пользователей OpenSuse 11.0,а также имею модем Globetrotter Icon 225
и хотелось бы подключить его к нету.
Делал как написано на этом сайте,запускается HSO connect(только под root),странички даже открывались,но через пару минут система вешалась наглухо и только Reset помогал,пишется что нужен скрипт для работы с Билайном,но т.к. я не в курсе как писать скрипт,и куда его класть,запускать -то хотел бы Вас попросить разЪяснить этот момент.
P.S.:А как запускать из-под обыкновенного пользователя?
Заранее благодарен.
Виталий из Мгн
ОС: ALT 4.0
Контактная информация:
Сообщение Виталий из Мгн »
А у меня - странности... Ночной безлимит подключил, но фиг там! Бабки как таяли, так и тают - при условии, что выхожу в Сеть только ночью. Номера у меня все - Билайн-Магнитогорск. Тают гораздо быстрее, нежель на "Клике" по дневному тарифу. Странно... От моей деревни до М-горска всего каких-то 20 р. пути любым автотранспортом. М-горская телевышка - видна из окна. "Клик" и "Удивительные вещи" - мотают по городскому тарифу. А "Интернет дома" - ведёт себя как-то странно! По междугородке могут они брать? всё-таки, тариф Интернет-дома! Может, Билайн-Уфа попробовать? Всё-таки Башкортостан. Я не знаю, где их ближайшая вышка стоит.
Обращаюсь ко всем, кто ездит на "элитный отдых" через нас. Подскажите, где окрест - поближе - можно подключить башкирский Билайн? Таштимерово? Елимбетово? Михайловка? Н-Самарское? В райцентр переться нет ни денег, ни желания в такие морозы.
...и 2 сада в Магнитогорске...
satch
ОС: удобная
Сообщение satch »
а не легче ли кого-нить из друзей попросить, кто в Уфу собирается ехать?
broom
Сообщение broom »
Если уж на то пошло, то в Билайн надо позвонить да спросить. Номер 0611.
Виталий из Мгн
ОС: ALT 4.0
broom писал(а):
07.01.2009 15:57
:crazy: 0611? Да они - фиг чё скажут по тех.части! Попробую найти м-горскую базу Билайна и лично пообщаться со спецами там. Раньше они базировались на КМ 64. Щас - ХЗ, куда съехали.
broom
Сообщение broom »
Виталий из Мгн писал(а):
07.01.2009 18:40
broom писал(а):
07.01.2009 15:57
Если попросить соединить с техническим специалистом, то скажут.
К тому же, списание денег - это не техническая часть.
Goodvin
Ведущий рубрики
Статус: ⚝⚠⚒⚑⚖☭☞☣☤&
Сообщение Goodvin »
mexx2 писал(а):
06.01.2009 10:32
Здравствуйте!
Симметрично.
mexx2 писал(а):
06.01.2009 10:32
Наверное, сейчас уже стоит попробовать openSUSE 11.1
Таки ядро там более свежее и поддержка этих железок должна быть получше.
mexx2 писал(а):
06.01.2009 10:32
Все эти вопросы многократно обсуждались на форуме и к сожалению выходят за рамки данной темы.
Воспользуйтесь поиском.
shpakser
Сообщение shpakser »
eugenlinux писал(а):
15.08.2008 10:07
1. без ПО Би Интернет Дома конечно можно соединиться с сетью (ставишь драйвер и работаешь как с модемом)
2. Linux и 3G конечно же дружат))) Проверял сам. Мегафон 3Г Питер. Всё ОК.
3. Вот настройки для ALT Linux 4:
1. вставляем модем
2. запускаем терминал, заходим под root
3. eject /dev/sr0 - происходит извлечение cdrom, коим видится модем
4. modprobe usbserial vendor=0x19d2 product=0x0001 , если нету, то /sbin/modprobe usbserial vendor=0x19d2 product=0x0001
5. dmesg | grep -i ttyUSB или dmesg | grep ttyUSB
6. модем должен зацепиться на ttyUSB0
дальше настраиваем соединение:
1. подключение по диалапу (KPPP)
2. настроить - соединение - создать - имя соединения (любое) - номер *99#
3. там же - модемы - создать - имя любое - устройство /dev/ttyUSB0 - там же вкладка МОДЕМ - команды модема - в СТРОКЕ ИНИЦИАЛИЗАЦИИ 2 пишем AT+CGDCONT=1,"IP","internet.beeline.ru" - остальное не трогаем. жмем ок, имя и пароль beeline. всё)
Это настройка модема у меня работала в mandriva 2008, а вот 2009 нет. Делаю так:
1. вставляю модем
2. запускаю терминал, захожу под root
3. eject /dev/uba1 - так как определяется как флешка
Модем определяется, заношу настройки, подключаюсь, показывает что есть подключение но не могу зайти на какой-нибуть сайт. Что я делаю не так???
f0b
Сообщение f0b »
всем привет, юзаю ZTE MF622. в linux (SUSE 11.0) с ним движухи имеются, но к интернет не подключается.
что делаю (цепляется на /dev/ttyUSB2):
при дозвоне:
есть ли решение?
в этом мире все относительно...
f0b писал(а):
13.01.2009 06:42
есть ли решение?
для решения нужна информация от pppd. опции dump и debug. куда именно их впихивать (исходя из того, что вы используете kinternet), увы, не подскажу.
p.s. сильно облегчает разбирательство просмотр лог-файла (с метками времени), а не абсолютно безинформативных скриншотов.
f0b
Сообщение f0b »
sash-kan писал(а):
14.01.2009 22:18
f0b писал(а):
13.01.2009 06:42
есть ли решение?
почему же "абсолютно безинформативных"? для меня ваша инфа о безинформативности очень даже информативна, теперь я знаю что разместить. )
Jafejfiya
Сообщение Jafejfiya »
Уважаемые, дистр Slackware 12.1, модем MF 622, оператор Beeline. Делаю, как здесь люди описывали, устройство переключается в режим модема, появляется на /dev/ttyUSB0, горит зелёная лампочка, в KPPP "модем готов", опрос модема - OK, а при попытке соединения - начинается "инициализация модема" и больше ничего не происходит. Пробовала вставлять разные строки инициализации, перечисленные здесь - не помогает. Уточните, плиз, какие строчки инициализации должны быть для этого модема?
Ради этого же модема установила ещё и PCBSD 7 (нужен спутниковый интернет, и крайне желательно не через Винду), пересобрала ядро. Вывод dmesg показывает, что система видит этот модем, появились /dev/cuaU0 и /dev/ttyU0, но при выборе в KPPP "опрос модема" система наглухо виснет и помогает только reset. Кто-нибудь запустил это чудо в PCBSD? Если да, то каким образом?
romuil
Статус: Ромунцель
ОС: ALTLinux Sisyphus
Сообщение romuil »
Строка инициализации вида AT+CGDCONT=1,"IP","точка_доступа"
Если вешается - скорее всего надо крутить опции pppd.
Спутникового интернета в BSD нет и когда будет не известно - скорее всего что никогда. С этим вопросом на форум BSD.
Alexxx
Статус: --==XXX==--
ОС: Archlinux current
Сообщение Alexxx »
По мотивам http://znoxx.wordpress.com/debian-at-eee/zte-beeline-balance выкладываю дополненную версию скрипта проверки баланса.
Выражаю благоданость to Subj, который написал цикл с printf`ом (landgraf присутствовал тоже, подтвердит, если что ;) ), когда я уже сам зациклился и у мну мозги задымились. Оказывается, всё просто. :)
У кого локаль не utf8, поправьте в iconv соответственно.
Всё это тестировалось с модемом ZTE MF626. Ядро 2.6.28/2.6.28.1, модуль option. В режиме онлайн работает ttyUSB1 (ttyUSB2 занят подключением), в оффлайн - оба интерфейса.
Исправления, доработки, дополнения приветствуются.
#!/bin/sh
SCR=/tmp/ussdscp
OST=/tmp/lastcheck
echo 'send "ATZ"'>$SCR
echo 'send ""' >>$SCR
echo 'send "AT+CUSD=1,*102#,15"'>>$SCR
echo 'expect {'>>$SCR
echo '"\"," ! killall -9 minicom'>>/$SCR
echo '   }'>>$SCR
echo '! killall -9 minicom'>>$SCR
minicom -S $SCR -C $OST >/dev/null 2>&1
) >/dev/null 2>&1
reset
BUF=$(grep '".*"' $OST |sed -e "s/\(.*\"\)\(.*\)\(\".*\)/\\2/")
for i in $(echo $BUF | grep -o ".."); do
   printf "\x$i"
done | iconv -f UCS-2BE -t UTF-8
echo ""
unlink $OST
unlink $SCR
Подправил немного на предмет минимизации дисковых операций:
-grep '".*"' $OST |sed -e "s/\(.*\"\)\(.*\)\(\".*\)/\\2/">$SCR
-for i in $(cat $SCR | grep -o ".."); do
+BUF=$(grep '".*"' $OST |sed -e "s/\(.*\"\)\(.*\)\(\".*\)/\\2/")
+for i in $(echo $BUF | grep -o ".."); do
Alexxx
Статус: --==XXX==--
Сообщение Alexxx »
Сегодня с помошью этого скрипта перешёл на другой тариф. Подставил s/*102#/*110*2100#/ , в ответ пришло "Ваша заявка принята. Дождитесь смс уведомления." Вот только не знаю как эти смски принимать. У кого какие идеи? Заодно и отправлять бы научиться. :)
Myxins
ОС: openSUSE 11.0
Сообщение Myxins »
Э-э-эх, еще на одного пользователя ZTE MF626 из-под линукса стало больше, наконец-то блин разобрался. Пару часов плясок с бубном вокруг модема, точнее его программной части, YaST'а и kppp дали результат. Если кого-то интересует, пишите в личку, отвечу, только предположительно ночью, ибо анлим.
07.01.2009 18:40
broom писал(а):
07.01.2009 15:57
А насчет тех службы - эт зря. У знакомого как-то сняли ни за что 162 рубля, он написал им на мыло, типа так делать не хорошо, в течении суток деньги вернули.
Myxins
ОС: openSUSE 11.0
Сообщение Myxins »
f0b писал(а):
13.01.2009 06:42
при дозвоне:
есть ли решение?
э-э... Вобщем я делал так на сусе 11.0
1) Поставил ядро 2.6.28 с поддержкой ACM CDC Modem, вроде так называется
2) Скачал программу QPST от Qualcomm и с помощью ее удалил 2 файлика, если прогуглить, то можно узнать каких, сейчас не помню, первый отрубает включение модема как сидирома, второй отключает пресловутую проверку каждую минуту.
3)Зашел в яст, сетевое оборудование, модем.
4)Он нашел модем и здесь самое главное - конфигурирование. Необходимо убрать галочку "обнаружить сигнал в сети". Далее все просто - либо kinternet, либо kppp, предпочитаю второе.
Antarex
Сообщение Antarex »
Благодаря помощи этой темы я разобрался с работой моего ZTE MF622 под Linux, но хотелось бы выходить в интернет под FreeBSD 7.1. Владельцев такого же модема, у которых есть возможность поставить FreeBSD 7.1 прошу о помощи!
ZTE MF622 поддерживается системой FreeBSD начиная с версии 7.1, то есть он отвечает на АТ-команды. Но выйти в интернет пока не удается, возможно проблема в том, что в FreeBSD, в отличие от Linux, не доступна опция DNS Auto setting в KPPP. При ручном вводе IP адреса DNS, который предоставили в техподдержке Билайна, при коннекте выводится сообщение об ошибке.
Skyb
ОС: RFremix 18
Сообщение Skyb »
я не всегда всё понимаю, прозьба полностью описать действия по запросу баланса(а именно я не понял то куда эту АТ команду посылать!!!)
C:\windows> ifconfig
"ifconfig" не является внутренней или внешней
командой, исполняемой программой или пакетным файлом.
Yorgen
ОС: Debian Lenny,Mandriva 2009
Сообщение Yorgen »
Доброй ночи! Возникла проблема с запуском модема ZTE MF626 под Debian Lenny.Воспользовался советами отсюда:http://ru.gentoo-wiki.com/wiki/MF626.Убрал CD_STARTUP_FLAG и FLAG_NO_DOWNLOAD Устройство определяется как нужно,согласно рецепту :),однако при подключении через Gnome PPP набирает номер,ждёт приглашения,затем снова номер,потом подключение разрывается. Dmesg | grep -i ttyUSB показывает 8.057561 usb 4-4: generic converter now attached to ttyUSB0.При повторном подключении Gnome PPP пишет,что модем не найден.Заранее спасибо.
Be Root... Think logically.
Yorgen
Сообщение Yorgen »
Сегодня утром,немного поспав и отдохнув,почитал лог Gnome-PPP,подозреваю,что проблема в командах модема,учитывая то,что MF626-helper собрать не смог вчера ( не помню уже почему),думаю,что дело в этом,буду курить маны :) Если что,извиняюсь за дурацкий пост :).
ppp_log.txt
(801 байт) 14 скачиваний
romuil
Статус: Ромунцель
Сообщение romuil »
Имеется модем HUAWEI E219
Определяется как
Feb 25 20:30:31 romul kernel: [ 3214.822397] usb 4-2: New USB device found, idVendor=12d1, idProduct=1003
Feb 25 20:30:31 romul kernel: [ 3214.822402] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 25 20:30:31 romul kernel: [ 3214.822406] usb 4-2: Product: HUAWEI Mobile
Feb 25 20:30:31 romul kernel: [ 3214.822410] usb 4-2: Manufacturer: HUAWEI Technologies
Появляется два устройства ttyUSB0 и 1
При соединении через kppp соединяется, но ничего не работает. Пишет
Could not determine remote IP address: defaulting to 10.64.64.64
и вешает левые DNS
Дистрибутив ALT Linux Desktop 4.1 ядро 2.6.28
Ответить
