какбыда
чипсет , SCSI, filesystem, SCSI Disc
и всё
USE-флаги с которыми собран xorg-server:
+ + dri
+ + input_devices_evdev
+ + input_devices_keyboard
+ + input_devices_mouse
+ + minimal
+ + nptl
+ + video_cards_fglrx
+ + video_cards_radeon
+ + video_cards_vesa
+ + xorg
# cat /var/log/Xorg.0.log|grep EE
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(EE) Failed to load module "xtt" (module does not exist, 0)
(II) Loading extension MIT-SCREEN-SAVER
(EE) fglrx(0): [agp] unable to acquire AGP, error -1023
(EE) fglrx(0): cannot init AGP
(EE) fglrx(0): atiddxDriScreenInit failed, GPS not been initialized.
(EE) fglrx(0): XMM failed to open CMMQS connection.
(EE) AIGLX: Screen 0 is not DRI capable
# lsmod
Module Size Used by
nls_iso8859_1 4352 0
sg 25900 0
sd_mod 26768 0
usb_storage 72384 0
scsi_mod 104072 3 sg,sd_mod,usb_storage
libusual 19104 1 usb_storage
fglrx 1681300 0
agpgart 33840 1 fglrx
af_packet 21504 0
nls_utf8 2304 1
nls_cp437 6016 1
vfat 13056 1
fat 50844 1 vfat
fuse 48284 6
usbmouse 5632 0
usbhid 30592 0
hid 40704 1 usbhid
snd_cmipci 35200 1
snd_pcm 73096 1 snd_cmipci
snd_page_alloc 10632 1 snd_pcm
snd_opl3_lib 9344 1 snd_cmipci
snd_timer 22404 2 snd_pcm,snd_opl3_lib
snd_hwdep 8708 1 snd_opl3_lib
snd_mpu401_uart 8192 1 snd_cmipci
snd_rawmidi 21248 1 snd_mpu401_uart
snd 46388 9 snd_cmipci,snd_pcm,snd_opl3_lib,snd_timer,snd_hwdep,snd_mpu401_uart,snd_rawmidi
soundcore 7648 1 snd
analog 11936 0
gameport 13832 2 snd_cmipci,analog
via_rhine 23816 0
mii 5888 1 via_rhine
floppy 57508 0
radeonfb 112448 0
fb_ddc 2816 1 radeonfb
i2c_algo_bit 6788 1 radeonfb
cfbcopyarea 4096 1 radeonfb
cfbimgblt 3200 1 radeonfb
cfbfillrect 4224 1 radeonfb
pcspkr 3072 0
ohci_hcd 23300 0
button 8336 0
i2c_sis96x 5380 0
i2c_core 24720 4 radeonfb,fb_ddc,i2c_algo_bit,i2c_sis96x
usbcore 143856 6 usb_storage,libusual,usbmouse,usbhid,ohci_hcd
evdev 11904 4
# dmesg|tail
[ 2629.953898] usbcore: registered new interface driver libusual
[ 2630.058285] SCSI subsystem initialized
[ 2630.151130] Initializing USB Mass Storage driver...
[ 2630.152215] scsi0 : SCSI emulation for USB Mass Storage devices
[ 2630.153246] usbcore: registered new interface driver usb-storage
[ 2630.153254] USB Mass Storage support registered.
[ 2630.153537] usb-storage: device found at 2
[ 2630.153540] usb-storage: waiting for device to settle before scanning
[ 2635.472646] scsi 0:0:0:0: Direct-Access JetFlash TS512MJFV30 0.00 PQ: 0 ANSI: 2
[ 2635.472975] usb-storage: device scan complete
uid=696(civil) gid=100(users) группы=7(lp),10(wheel),18(audio),19(cdrom),27(video),35(games),85(usb),100(users),410(scanner)
cat /etc/passwd | grep имя_пользователя | cut -d : -f 3
usermod -u ваш_новый_uid slava
chown -R slava /home/slava
chmod 755 /home/slava
SLV писал(а): ↑25.10.2008 13:56Теперь есть другая не менее интересная проблема: если зайти как обычный пользователь, ввести в любой консоли su и свои пароль, я получаю надпись: доступ запрещен. Если ввожу sudo и команда, получаю надпись, что ваш сисадмин наверняка читал вам лекцию суть которой обычно сводится к трем пунктам.
Хм.. У мя на eee pc один и тот же пароль и на юзера и на рута, и ничё, работает, правда там дебиан, но не думаю что в этом дело...SLV писал(а): ↑25.10.2008 21:42Так весь прикол в том, что если я ввожу в консоли (без гуи) логин root и пароль рута, я захожу. Но su при вводе правильного пароля рута, не заходит. Может все потому, что пароль моей учетки и рута одинаков? И когда-то я пытался его поменять, мне passwd ругнулся на словарное слово.
gpasswd -a имя_пользователя имя_группы #добавить в группу
gpasswd -d имя_пользователя имя_группы #удалить из группы
nano etc/env.d/02locale , он был пустым - добавляем LANG="ru_RU.UTF8" , сохраняем. Далее env-update, далее source /etc/profile , для проверки вводим locale и смотрим результат. Везде в конце строк должно быть UTF8.
SLV писал(а): ↑26.10.2008 14:56Теперь появилось еще 2 проблемы. Пока что нерешенные. 1. Я так и не смог настроить переключение раскладок клавиатуры. Пробовал двумя способами - через Центр управления KDE и через xorg.conf. C xorg.conf поступил просто - взял мандривовскую секцию для input device и скопировал оттуда модель клавиатуры и опции. Через центр управления проблема решается частично. Я смог сделать переключение по щелчку на XkbSwitcher, но мне надо нажатие ctrl+shift. Вторая проблема - нету звука. Кстати, странно. Когда я работал в Xfce4 под рутом, я вводил какую-то команду для вызова конфигуратора alsa, который все мне сделал. А сейчас я потерял сайт, с которого эту команду узнал.
Option "XkbLayout" "us,ru(winkeys)"
Option "XkbOptions" "grp:ctrl_shift_toggle,grp_led:scroll"
rm -f libQtDesigner.so.4.4.2 libQtDesigner.so libQtDesigner.so.4 libQtDesigner.so.4.4
linking ../../../../lib/libQtDesigner.so.4.4.2
/usr/lib/gcc/i686-pc-linux-gnu/4.3.2/../../../../i686-pc-linux-gnu/bin/ld: cannot find -lQtScript
make[2]: *** [../../../../lib/libQtDesigner.so.4.4.2] Error 1
make[2]: Leaving directory `/var/tmp/portage/x11-libs/qt-gui-4.4.2/work/qt-x11-opensource-src-4.4.2/tools/designer/src/lib'
make[1]: *** [sub-lib-make_default-ordered] Error 2
make[1]: Leaving directory `/var/tmp/portage/x11-libs/qt-gui-4.4.2/work/qt-x11-opensource-src-4.4.2/tools/designer/src'
make: *** [sub-src-make_default] Error 2
[31;01m*[0m
[31;01m*[0m ERROR: x11-libs/qt-gui-4.4.2 failed.
[31;01m*[0m Call stack:
[31;01m*[0m ebuild.sh, line 49: Called src_compile
[31;01m*[0m environment, line 2694: Called qt4-build_src_compile
[31;01m*[0m environment, line 2469: Called build_target_directories
[31;01m*[0m environment, line 347: Called build_directories '
[31;01m*[0m src/gui
[31;01m*[0m tools/designer
[31;01m*[0m tools/linguist
[31;01m*[0m src/plugins/imageformats/gif
[31;01m*[0m src/plugins/imageformats/ico
[31;01m*[0m src/plugins/imageformats/jpeg tools/qdbus/qdbusviewer src/plugins/imageformats/tiff'
[31;01m*[0m environment, line 342: Called die
[31;01m*[0m The specific snippet of code:
[31;01m*[0m emake || die "emake failed";
[31;01m*[0m The die message:
[31;01m*[0m emake failed
[31;01m*[0m
[31;01m*[0m If you need support, post the topmost build error, and the call stack if relevant.
[31;01m*[0m A complete build log is located at '/var/tmp/portage/x11-libs/qt-gui-4.4.2/temp/build.log'.
[31;01m*[0m The ebuild environment file is located at '/var/tmp/portage/x11-libs/qt-gui-4.4.2/temp/environment'.
[31;01m*[0m
/usr/lib/gcc/i686-pc-linux-gnu/4.3.2/../../../../i686-pc-linux-gnu/bin/ld: cannot find -lQtScript collect2: ld returned 1 exit status
Ну и для убунту тоже нашел ответикFindQt4.cmake of cmake-2.4.7 does not know the QtScript module. Fixed by importing and slightly patching KDE's cmake modules.
только мне на убунту это не надо, а qt4-dev-tools я в портежах не нашел.apt-get install qt4-dev-tools an qt4-designer
CFLAGS="-O2 -march=core2 -pipe -fno-strict-aliasing -fomit-frame-pointer"
CXXFLAGS="${CFLAGS}"
я не нашел название пакета русской локализации
# /etc/locale.gen: list all of the locales you want to have on your system
# The format of each line:
# <locale> <charmap>
# Where <locale> is a locale located in /usr/share/i18n/locales/ and
# where <charmap> is a charmap located in /usr/share/i18n/charmaps/.
# All blank lines and lines starting with # are ignored.
# For the default list of supported combinations, see the file:
# /usr/share/i18n/SUPPORTED
# Whenever glibc is emerged, the locales listed here will be automatically
# rebuilt for you. After updating this file, you can simply run `locale-gen`
# yourself instead of re-emerging glibc.
#en_US ISO-8859-1
#en_US.UTF-8 UTF-8
#ja_JP.EUC-JP EUC-JP
#ja_JP.UTF-8 UTF-8
#ja_JP EUC-JP
#en_HK ISO-8859-1
#en_PH ISO-8859-1
#de_DE ISO-8859-1
#de_DE@euro ISO-8859-15
#es_MX ISO-8859-1
#fa_IR UTF-8
#fr_FR ISO-8859-1
#fr_FR@euro ISO-8859-15
#it_IT ISO-8859-1
eselect opengl set nvidia
checking for kde-config... not found
configure: error: The important program kde-config was not found!
Please check whether you installed KDE correctly.
, и заодно просветит насчет OpenGL Nvidia 8800GT и Gentoo 2008 x86? Я уже кое-как поборол отсутствие Direct Rendering, но все равно артефакты со включенным OpenGL есть и они очень мешают жить. Добавлялся в группу video, переключался на nvidia opengl interface, загружал модуль nvidia и добавил его в автозагрузку. Может я чего не так сделал или не сделал?checking for kde-config... not found
