Ну так и расскажите, что изменилось, что нового появилось.
Total Annihilation: Spring (Обсуждение нативной игры, решение проблем.)
Re: Total Annihilation: Spring
Хо... мы уже на Вы??
а по простому - работает стабильно - ни разу не вылетела . Кстати - будет здорово - если кто то сможет перевести - я по англицки не очень
Whats new:
Rewritten AI interface in C
Despite the fact that the old one was a mess left over from the earlymost days of spring, the new interface allows a greater flexibility of AI-development. The old group-AIs where removed altogether, because they had already been replaced by lua-scripts.
Soundworks
Audio effects are another area which lacked love for a long time. Instead of having different sound renderers for unix and windows, there is now a single cross-platform library, so it sounds the same on all platforms spring runs on. Other gimmicks are newly added effects doppler effects, pitch adjustment for gamespeed etc. But the most advantage provides the new "sounds.lua"-file, which gives you fine-grained control over various aspects of sound effects while beeing fully backwards-compatible.
Improved UI-appearance
You will immediately notice that something changed in the interface. The old fonts where replaced by something new and shiny, while the renderer got an overhaul to produce better readable text. This also fixed various bugs, improved the handling of 16:9 displays and provides better window resizing support.
Other noteworthy changes
numerous rendering fixes for broken cards and drivers (mostly ATI)
raise some engine limitations (now 250 players can play in 250 team with 32000 units)
Summary: 2292 files changed, 149700 insertions, 290245 deletions
For a complete list of all the changes, check out the shortlog:
http://springrts.com/dl/spring_0.79.0_changelog.txt
...Все в наших руках...
Обясните мне в эту игру можно играть offline или только online ????
- Gena_Zakharov
- ОС: Kubuntu/Debian/Gentoo
- Контактная информация:
Шикарная новость. В это игру я рубился еще давным давно (даже и не помню точно когда). Одна из моих любимых.
Обязательно скачаю.
Теперь бы выпустить еще Majesty на этом же движке, и вообще будет сказка.
Обязательно скачаю.
Linux 32bit spring installer 0.79.1.0 5-29-2009
Linux 64bit spring installer 0.79.1.0 5-29-2009
блиииинн
11:56:48: runtime assertion ( /home/az/Spring/src/springg/src/tasserver.cpp:1664 ): invalid m_battle_id value
и так почти каждую игру...
Анализ подозрительных файлов тут
Все что вы скажете может быть использовано как баян.
Jabber-конференция: sysadmins.ru на conference.jabber.ru - всем добро пожаловать!
12:09:29: GlobalsManager::DestroyAll(), runtume_error 'trying to access global during or after DestroyAll' when destroying
12:09:29: TorrentWrapper::~TorrentWrapper()
*** glibc detected *** /usr/local/bin/springlobby: double free or corruption (out): 0x0000000003178620 ***
======= Backtrace: =========
/lib/libc.so.6[0x7fa6425b7118]
/lib/libc.so.6(cfree+0x76)[0x7fa6425b8c56]
/usr/lib/tls/libnvidia-tls.so.1[0x7fa639450a3b]
======= Memory map: ========
00400000-00b25000 r-xp 00000000 08:05 547977 /usr/local/bin/springlobby
00d25000-00d7e000 rw-p 00725000 08:05 547977 /usr/local/bin/springlobby
00d7e000-00da8000 rw-p 00d7e000 00:00 0
0275c000-03bdf000 rw-p 0275c000 00:00 0 [heap]
40a2d000-40a2f000 rwxp 00000000 00:0d 1186 /dev/zero
7fa624000000-7fa624302000 rw-p 7fa624000000 00:00 0
7fa624302000-7fa628000000 ---p 7fa624302000 00:00 0
7fa628378000-7fa62838b000 r-xp 00000000 08:01 123261 /lib/libresolv-2.9.so
7fa62838b000-7fa62858b000 ---p 00013000 08:01 123261 /lib/libresolv-2.9.so
7fa62858b000-7fa62858c000 r--p 00013000 08:01 123261 /lib/libresolv-2.9.so
7fa62858c000-7fa62858d000 rw-p 00014000 08:01 123261 /lib/libresolv-2.9.so
Кто-нибудь Spring: 1944 пробовал, как оно?
Да в общем то неплохо, правда с анимацией у них там проблеммы, кривоватая маленько. Но вреде его активно пилят.
- Gena_Zakharov
А я пока играюсь в классический XTA. Все здорово, графика на высоте.
В общем, движок получился шикарный.
Единственный недостаток -- периодически выскакивают какие-то предупреждения со скриптами. Может быть, это зависит от выбора AI, нужно будет попробовать.
Одно из главных пожеланий -- выбор уровня сложности для AI. Иначе играть довольно тяжко.
Linux 32bit spring installer 0.80.5 10-23-2009
Linux 64bit spring installer 0.80.5 10-23-2009
А как к ней моды и карты ставить после установки?
[rain@rainland ~]$ ls -l /home/rain/Games/Spring/
итого 17592
drwxr-xr-x 4 rain rain 4096 2009-06-02 00:45 AI/
-rw-rw-r-- 1 rain rain 14811 2009-09-24 21:48 ArchiveCacheV7.lua
drwxrwxr-x 3 rain rain 4096 2009-06-02 00:45 base/
-rw-r--r-- 1 rain rain 2404 2009-06-02 00:45 cmdcolors.txt
-rw-r--r-- 1 rain rain 2757 2009-06-02 00:45 ctrlpanel.txt
-rwxrw-r-- 1 rain rain 89 2009-06-02 00:45 dedicatedstart.sh*
drwxr-xr-x 2 rain rain 4096 2009-09-24 23:17 demos/
-rw-rw-r-- 1 rain rain 3799 2009-09-24 21:48 ext.txt
drwxr-xr-x 2 rain rain 4096 2009-06-02 00:45 fonts/
-rw-rw-r-- 1 rain rain 63061 2009-09-24 23:17 infolog.txt
drwxr-xr-x 2 rain rain 4096 2009-06-02 00:45 libs/
-rw-r--r-- 1 rain rain 1766228 2009-06-02 00:45 libunitsync.so
drwxr-xr-x 3 rain rain 4096 2009-06-02 00:45 lobby/
drwxr-xr-x 10 rain rain 4096 2009-06-02 00:45 LuaUI/
-rw-r--r-- 1 rain rain 1817 2009-06-02 00:45 luaui.lua
-rw-rw-r-- 1 rain rain 1988 2009-06-21 15:27 lups.cfg
drwxr-xr-x 3 rain rain 4096 2009-09-24 21:24 maps/
drwxr-xr-x 2 rain rain 4096 2009-06-21 00:59 mods/
drwxr-xr-x 7 rain rain 4096 2009-06-02 00:45 MojoSetup/
-rw-r--r-- 1 rain rain 1024 2009-06-02 00:45 PALETTE.PAL
-rw-rw-r-- 1 rain rain 1698 2009-09-24 21:48 script.txt
-rw-r--r-- 1 rain rain 472 2009-06-02 00:45 selectkeys.txt
-rwxr-xr-x 1 rain rain 11207228 2009-06-02 00:45 spring*
-rwxr-xr-x 1 rain rain 20576 2009-06-02 00:45 spring-dedicated*
-rw-r--r-- 1 rain rain 6764 2009-06-02 00:45 springicon.png
-rwxr-xr-x 1 rain rain 4647052 2009-06-02 00:45 springlobby*
-rwxrw-r-- 1 rain rain 84 2009-06-02 00:45 springstart.sh*
-rw-r--r-- 1 rain rain 103135 2009-06-02 00:45 TASServer.jar
-rw-r--r-- 1 rain rain 3139 2009-06-02 00:45 tasserver_readme.txt
-rw-r--r-- 1 rain rain 4027 2009-06-02 00:45 teamcolors.lua
-rw-r--r-- 1 rain rain 14407 2009-06-02 00:45 uikeys.txt
-rwxr-xr-x 1 rain rain 78 2009-06-02 00:45 uninstall-Spring.sh*
-rw-rw-r-- 1 rain rain 9524 2009-09-24 23:17 unitsync.log
Кладете моды в каталог mods
[rain@rainland ~]$ ls -l /home/rain/Games/Spring/mods/
итого 176888
-rw-r--r-- 1 rain rain 13674995 2007-05-06 15:27 AA3.2.sd7
-rw-rw-r-- 1 rain rain 14002603 2009-06-21 00:58 BA695.sd7
-rw-rw-r-- 1 rain rain 79068790 2009-05-01 12:58 ca-r4460.sdz
-rw-rw-r-- 1 rain rain 20637822 2009-06-20 22:32 NOTA158.sd7
-rw-r--r-- 1 rain rain 21733558 2009-04-04 01:19 XTA_Installer_Version.sdz
-rw-rw-r-- 1 rain rain 31791698 2009-05-01 12:26 XTAPEV958.sdz
итого 17592
итого 176888
Глюки с сохранением игры. Тоесть игра вроде сохраняется нормально, но когда пытаюсь загрузить, то пишет типа это сохранение не подходит для вашей версии игры. Если беру все равно продолжить, то начинает загружать и вылетает с сегфолтом. Что делать?
Кто-нибудь пробовал писать виджеты под нее на luaui? Буду благодарен за ссылки на любые ресурсы по теме.
upd. Для начала интересуют основные функции взаимодействия движка и виджетов(инициализация, возможности работы с текстовыми командами, привязки функций на хоткей)
