Xsession: X session started for scad at Пт 12 авг 2022 14:18:49 MSK
dbus-update-activation-environment: systemd --user not found, ignoring --systemd argument
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-RLMuH2wuRC,guid=59a593e8c41a011ceb62b2c762f63719
dbus-update-activation-environment: setting DISPLAY=:2300
xhost: must be on local machine to add or remove hosts.
localuser:scad being added to access control list
dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dbus-update-activation-environment: setting SUDO_GID=1001
dbus-update-activation-environment: setting MAIL=/var/mail/scad
dbus-update-activation-environment: setting LANGUAGE=ru_RU
dbus-update-activation-environment: setting USER=scad
dbus-update-activation-environment: setting LC_TIME=ru_RU.UTF-8
dbus-update-activation-environment: setting SSH_AGENT_PID=13037
dbus-update-activation-environment: setting SHLVL=1
dbus-update-activation-environment: setting BROWSER=/usr/bin/firefox
dbus-update-activation-environment: setting HOME=/home/scad
dbus-update-activation-environment: setting LC_MONETARY=ru_RU.UTF-8
dbus-update-activation-environment: setting NXUSERIP=192.168.1.149
dbus-update-activation-environment: setting SUDO_UID=1001
dbus-update-activation-environment: setting IM_CONFIG_PHASE=1
dbus-update-activation-environment: setting LOGNAME=scad
dbus-update-activation-environment: setting _=/usr/bin/ssh-agent
dbus-update-activation-environment: setting TERM=unknown
dbus-update-activation-environment: setting PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
dbus-update-activation-environment: setting LC_ADDRESS=ru_RU.UTF-8
dbus-update-activation-environment: setting LANG=ru_RU.UTF-8
dbus-update-activation-environment: setting LC_TELEPHONE=ru_RU.UTF-8
dbus-update-activation-environment: setting HELP_BROWSER=/usr/bin/firefox
dbus-update-activation-environment: setting SUDO_COMMAND=/bin/bash -c /usr/bin/nxnode --startsession
dbus-update-activation-environment: setting SHADOW_XAUTHORITY=/home/scad/.nx/C-mint03-2300-5E67D1C187F5028AA822BB734F04FBD8/authority
dbus-update-activation-environment: setting SSH_AUTH_SOCK=/tmp/ssh-XXXXXX8Imgqq/agent.13036
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting LC_NAME=ru_RU.UTF-8
dbus-update-activation-environment: setting SUDO_USER=nx
dbus-update-activation-environment: setting LC_MEASUREMENT=ru_RU.UTF-8
dbus-update-activation-environment: setting LC_IDENTIFICATION=ru_RU.UTF-8
dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
dbus-update-activation-environment: setting PWD=/home/scad
dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/xfce4:/home/scad/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
dbus-update-activation-environment: setting LC_NUMERIC=ru_RU.UTF-8
dbus-update-activation-environment: setting LC_PAPER=ru_RU.UTF-8
dbus-update-activation-environment: setting NXSESSIONID=mint03-2300-5E67D1C187F5028AA822BB734F04FBD8
/usr/bin/x-session-manager: X server already running on display :2300
xfce4-session-Message: 14:18:50.739: SSH authentication agent is already running
gpg-agent: агент gpg уже запущен - еще один, новый, запущен не будет
(xfwm4:13285): xfwm4-WARNING **: 14:18:50.897: XSync extension too old (3.0).
(xfwm4:13285): xfwm4-WARNING **: 14:18:50.906: The display does not support the XComposite extension.
(xfwm4:13285): xfwm4-WARNING **: 14:18:50.907: The display does not support the XPresent extension.
(xfwm4:13285): xfwm4-WARNING **: 14:18:50.907: Compositing manager disabled.
(xfsettingsd:13306): xfsettingsd-CRITICAL **: 14:18:51.053: Your XI is too old (1.3) version 1.4 is required.
(xfsettingsd:13306): xfsettingsd-WARNING **: 14:18:51.054: Failed to create device filter
** (polkit-gnome-authentication-agent-1:13324): WARNING **: 14:18:51.719: Unable to register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: User of caller and user of subject differs.
Cannot register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: User of caller and user of subject differs.
/usr/bin/xfce-autostart-wm:13: PyGIDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "schema" or use a class specific constructor. See:
https://wiki.gnome.org/PyGObject/InitializerDeprecations
settings = Gio.Settings("com.linuxmint.desktop")
Process already running (98:Адрес уже используется). Exiting.
/usr/lib/linuxmint/mintUpdate/mintUpdate.py
DeprecationWarning: Gdk.threads_init is deprecated
Gdk.threads_init()
(wrapper-2.0:13340): GLib-GIO-CRITICAL **: 14:18:52.421: g_file_new_for_path: assertion 'path != NULL' failed
(wrapper-2.0:13340): GLib-GIO-CRITICAL **: 14:18:52.421: g_file_monitor_file: assertion 'G_IS_FILE (file)' failed
(wrapper-2.0:13340): GLib-GObject-WARNING **: 14:18:52.421: invalid (NULL) pointer instance
(wrapper-2.0:13340): GLib-GObject-CRITICAL **: 14:18:52.421: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(wrapper-2.0:13340): Gtk-WARNING **: 14:18:52.421: Attempting to add a widget with type GtkToggleButton to a container of type XfcePanelPlugin, but the widget is already inside a container of type XfcePanelPlugin, please remove the widget from its existing container first.
DeprecationWarning: Gtk.ImageMenuItem.set_image is deprecated
menuItem3.set_image(image)
/usr/lib/linuxmint/mintUpdate/mintUpdate.py:731: DeprecationWarning: Gdk.threads_enter is deprecated
Gdk.threads_enter()
/usr/lib/linuxmint/mintUpdate/mintUpdate.py:738: DeprecationWarning: Gdk.threads_leave is deprecated
Gdk.threads_leave()
(wrapper-2.0:13330): Gtk-WARNING **: 14:18:52.605: gtk_widget_size_allocate(): attempt to allocate widget with width -1 and height 24
(wrapper-2.0:13340): Gtk-WARNING **: 14:18:52.652: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner GtkToggleButton)
